Steering wheel control issues after SYNC 3.4 update
I had a 2015 F150 King Ranch. Now have a new to me 2017, 100k miles, one owner. I updated to SYNC 3.4. I can’t say if the update caused the issues bc I updated it the day after I bought it but the previous owner said he’d never experienced any issues. Since the update, a lot of times the volume up button will change the source and / or toggle through the presets. It is random and intermittent and does it with or without my phone attached. I noticed today when towing a small trailer the OK button didn’t work correctly. I feel sure the trailer issue wouldn’t be caused by the update but what about the volume up control? I see that I cannot downgrade back to 3.0. Thanks for any help!
Old SYNC Version: 3.0
Did you follow the install with a Master Reset?
Yes I did that immediately.
Can you beg borrow or steal some replacement steering wheel switches to test with?
Hmmm…not sure I do. From what I’ve read I was thinking clock spring but it seems too coincidental. And the fact the previous owner had zero issues.
A faulty clock-spring would generally leave the button(s) intermittent or inoperable.
First thing is that this is a 2015 which didn’t come with Sync 3 so somebody had to do a conversion.
I’m going to hazard a guess that the AsBuilt config here is a bit out of whack since it would have to be a custom one instead of the original factory AB.
Would that cause intermittent /sporadic operation??
I no longer have the 2015. This is my 2017
Sorry, did not read that
Check with ForScan to see if you’re throwing any codes.
