Sync 2 to Sync 3 missing temperature/fan dial on screen
I have recently upgraded my 2013 F-150 platinum from sync 2 to sync 3. I copied the as-built data from someone elses raptor as they have most of the same features (climate seats etc..) everything seems to work fine except the temperature dial that should pop up when changing the temperature.
Old SYNC Version: 3.0
New SYNC Version: 3.0
no
You’ve got a bad setting in the APIM AsBuilt or a compatibility problem with the FCIM.
Might want to look on the F150 forum since that’s dedicated to that model.
