Had 21265 before. Sync3updater updated the app version. then for whatever reason, no dropdowns for Sync version i wanted to install. Tried restarting app, same thing. Ended up reinstalling Sync3updater after downloading the installer. worked.
22020: installed and did master reset. don’t see any new changes. I have a 10" screen too.
So far so good on my old G series APIM. I know in the Discord it was mentioned this version potentially had some high CPU usage concerns. Just in the brief 15 minutes or so of messing with it in my garage while doing some FordPass/TCU related stuff it seems fine. No performance changes for better or worse. Just Works ™.
“Regarding the new version, it’s not yet available. 22020 has been cancelled due to (probably) bugs found during the test period. 22048 is the new that is currently under testing phase, if everything will go as expected, i think it will be published in April.”
