Guys
I have just upgraded my Sync 3 from 3.0 to 3.4
I selected Keep Existing Maps.
My Sync updated to 3.4 but Nav is not working. Have my existing maps been deleted due to a format on the Sync.
Shall i do another install with 3.4 but include the latest maps this time ??
Can you help please.
Thanks
Martin
Did you perform a Master Reset?
Yes, did a master reset.
When i look at the Sync version its at 3.4 but no details of maps.
Can you get to the IVSU Configuration display and check the map files?
Or what does it say on the Sync info screen?
If youâve gone from 3.0 to 3.4, then you have reformatted due to the different file partition, you canât keep existing maps as youâve effectively wiped the system. You will need to run the program again and select maps, make sure to change the configuration to the version you have now.
I missed the detail, you upgraded from 3.0.to 3.4âŚYes you need to include the maps.
@andspenka beat me to it. Thanks for the replyâŚ
@CyanLabs - maybe something to address in the app, canât keep existing maps if going from 3.0.to 3.2+âŚ
Thanks. Thats exactly what I thought. Pity it gave the option on âkeep existing mapsâ.
Am I okay to re-install the same version of 3.4 but also include the latest F9 maps ??
Many thanks guys.
Ive already downloaded it to USB, and ill do the install tomorrow. Will let you know the outcome.
It shouldnât be possible to select âkeep existing mapsâ if you correctly put your âcurrent versionâ
Issue is user error not my application
Apologies if this was an error on my part.i
However, I have uploaded again to the car, including F9 maps, and all seems fine.
Keep up the good work guys !
Thanks
Glad to hear it, no worries about user error, i was just pointing out to F150 that if configured correctly itâs not possible to do what he was suggesting i fix.
I have the same issue - But I canât get the maps file to copy to the usb.
Any thoughts?
Ive tried on two separate computers and two different USB.
INFO: Starting process (Sync 3.4.20196 - ANZ - 1.19 (2019) - ANZ, SA and TW)
INFO: Verifying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Successfully Verified 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Verifying 4U5T-14G423-DA_123696.tar.gz
INFO: Successfully Verified 4U5T-14G423-DA_123696.tar.gz
INFO: Verifying 5U5T-14G391-DM_1598636566000.TAR.GZ
INFO: Successfully Verified 5U5T-14G391-DM_1598636566000.TAR.GZ
INFO: Verifying 4U5T-14G421-DAE_1580861228000.TAR.GZ
INFO: Successfully Verified 4U5T-14G421-DAE_1580861228000.TAR.GZ
INFO: Verifying 4U5T-14G422-DF_1580862443000.TAR.GZ
INFO: Successfully Verified 4U5T-14G422-DF_1580862443000.TAR.GZ
INFO: Verifying 4U5T-14G424-DAE_1582148468000.TAR.GZ
INFO: Successfully Verified 4U5T-14G424-DAE_1582148468000.TAR.GZ
INFO: Creating downgrade reformat.lst
INFO: Creating downgrade autoinstall.lst
INFO: Copying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Copying 4U5T-14G423-DA_123696.tar.gz
INFO: Copying 5U5T-14G391-DM_1598636566000.TAR.GZ
INFO: Copying 4U5T-14G421-DAE_1580861228000.TAR.GZ
WARN: Failed to verify 4U5T-14G421-DAE_1580861228000.TAR.GZ retrying
INFO: Failed to copy/validate 4U5T-14G421-DAE_1580861228000.TAR.GZ , retrying #0
INFO: Failed to copy/validate 4U5T-14G421-DAE_1580861228000.TAR.GZ , retrying #1
INFO: Failed to copy/validate 4U5T-14G421-DAE_1580861228000.TAR.GZ , retrying #2
INFO: Copying 4U5T-14G422-DF_1580862443000.TAR.GZ
INFO: Copying 4U5T-14G424-DAE_1582148468000.TAR.GZ
