Discussion topic for SYNC 3 Cut Down Map Package Generator
Use this generator to create “Cut Down Map Packages” for Syn3Updater for APIM’s without enough space for full packages
Originally published at: Cut Down Map Package Generator - CyanLabs
Hi
I have a 32 GB sync3 system from Aliexpress (3.4-21020, F10 maps) , I live in Sweden so I used the cut down map package generator to fit EU F11 maps on it (3.4-22110).
The size of the resulting USB Image is 14.4 GB.
I have read the guides regarding sync3 sizing, but I am still not sure it will fit.
Will it fit ?
It should do
Thank you for answering so fast, I will update my sync3 system as soon as possible and give some feedback
Hi @CyanLabs , thanks for this, I was able to install the cutdown version of F11 EU maps in my MY20 EU APIM, it took around 40 minutes
Hi, Just updated my sync 3.4 to the latest sync 3.4 build to update the ANZ maps. Brilliant! Only a few minor issues.
Will Cyanlabs be offering a cut down map package for the ANZ maps in the future?
If it’s available and not ESN locked yes but unfortunately ANZ doesn’t have any cut down packages currently and probably never will
Thank you for the quick response.
Would it be possible to fit the EU pack that includes The Netherlands on a non nav unit? I do not know if I have a 8GB or 16GB unit, is there a way to check that?
Thanks!
Run an interrogator log
Thanks! Seems I have an 8GB APIM so that would not work!
I can’t find Denmark as an option on the Cut Down Map Package Generator page.
Is it there among the other Nordic countries, or isn’t Denmark a possible choice?
Danish voice is in the same group as the other Scandinavian voices.
-BCx EU North UK: DK (Denmark), SE (Sweden), NO (Norway), FI (Finland), IS (Iceland), UK (UK), IE (Ireland), IM (Isle of Man)
Apologies , seems I missed Denmark off the description
EDIT: Updated with “Denmark”
Map releases depend on Ford, not Cyanlabs.
About cut down maps no, since it’s already a single package.
And in the future, do not spam the same question all over the place.
I see. Thank you for your answer
Sir,
Where can I cut down map package for Middle East?
kindly advic
Syn3Updater already has that implemented, it enables you.to.select which region you would like. Have you checked it?.
Yes , but my question where to get the code for Middle East?
