Since information about those Sync 2.5 ACMs is scarce, and due to my lack of time to explore solutions and programming alternatives, as well as the inconclusive results from solutions already tested by other users, I decided to buy a “dumb” ACM from a similar vehicle. No hassle to configure… just straight to the point
Hello
I installed Sync3 plus in my Ford Ka. Everything was configured but I got two errors from ACM
U0142 Lost Communication With Body Control Module “B”
U0100 Lost Communication With ECM/PCM
What can I check?
Additionally, the temperature on the sync3 screen is two dashes. At the moment I have turned off the temperature display but maybe someone knows what could be the reason.
those codes are in apim module? or which one?
In forscan DTCs issue.
In ACM
