Separating messages so I don’t mess up all those issues. I’d also like your advice on a few things:
I started setting up APIM with all ADAS and things related to my specific car and noticed:
S&S shows in vehicle settings, but I can’t change its value from enabled to disabled. If I press the physical button on the center console, it shows disabled. When I click it on the screen, it makes the beep sound, so I thought it should work like a button? Not sure if it’s just for display or if it should actually toggle.
Settings like perimeter alarm, wipers on reverse, mirrors autofold are grayed out. But if I set them on the IPC, they work. So why are they blocked on the APIM?
I have a manual AC unit (j1bt-19980-aa). When setting it up via HVAC controls, fan speed shows fine on the APIM screen. But for temperature, it just says “temperature” with an empty bar — no value. Is that expected behavior for manual AC or a config issue?
