I actually try to upgrade my Sync 3.3 to 3.4 with the new F9 Maps
Ford Ranger Raptor 2019
EU
The upgrade is running since 2h and 50 min in total. simce nearly 2 hours its running the extract of voice nav package.
Actually it seems a little bit long. Is it normal in this case? This is , second try. At the first try I had an error PKG_ERRO3 for 4U5T-14G422-158086185400.tar.gz
I redownloaded this file and startet the upgrade again (the sync waited and said please insert usb. after insertig the usb it started normally.
Can’t say if it’s stuck because the wallpapers and the clock are still running.
Please don’t @ me i will reply when i have time, this isn’t my day job.
Should take at most ~60 minutes, clearly something has gone wrong, i would suggest using a different USB one that is well known such as sandisk, kingston etc and try again.
