What is your SYNC Region? Eu
What is your current SYNC Version? 3.4.20351
Do you have Navigation? Yes
---- error in 1U5T-14G421-BEH_1615430614000.TAR.GZ : sign_error02
Im installing the new map and sync version right now and i get this error code with a red screen!!
I used the program for Windows and used the correct current version.
What to do?
Will it fixe itself?
Did you force autoinstall? Can you provide a log?
I just use the auto settings of the cyanlabs Windows program
I Think it was autoinstall
Cant provide a log at this moment because im still in my car atm. Im hoping it will continue by itself at some point
What should i do? Wont i Brick my sync system if i turn off my car??
Does sign error mean that i used i wrong version? I really dont understand that cause i double checked my current version
Shut down my car and Trying to update again…
sign error is likely a bad usb which has corruped the package and therefore the SIGNature fails to be validated.
Also, once you finish / abort the process, send us the log to see how you created the USB.
Ok i will format the usb and dowload the files again. Will try again when finished
is there a way to know the APIMS size. is it 8GB or 16GB or 32GB
avdonr
#9
Run the interrogator utility from the updater app. Upload the log file and it’ll tell you the size.
system
closed
#10
