Hi!
I updated SYNC 3 on my 2022 Ford Kuga from version 3.4.21194 to 3.4.26057, and everything went smoothly. The problem arose when I tried to update the maps from version F10 to F13 and the engine accidentally shut off. I tried to resume the update, but since then, I keep getting error MEM_ERR03. I’ve performed a master reset, tried the RW data cleaner USB, and even attempted to edit autoinstall.lst to install only the voice packs and Gracenote, yet I still get the same error.
I might be skipping a step or doing something wrong, I’m not sure. Can someone help me and tell me step by step what should I do please?
interrogator log
VIN: WF0FXXWPM
APIM Model: NU5T-14G371-GAA
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 12G
Version 3.4.26057 (NU5T-14G381-AE)
11.10.2026 11:14:40 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 976K / 1.2G
/fs/sd/MAP/ = 15M / 3.0G
/fs/sd/MAP/ = 14M / 2.4G
/fs/sd/MAP/ = 7.8M / 1.6G
/fs/sd/MAP/ = 17M / 2.4G
/fs/sd/MAP/ = 26M / 3.7G
/fs/sd/MAP/ = 312K / 41M
/fs/sd/MAP/ = 4.9M / 3.4G
/fs/sd/MAP/ = 27M / 3.4G
/fs/Nuance/ = 29M / 5.0G
/fs/Nuance/ = 30M / 5.2G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 38M / 3.9G
/fs/Nuance/ = 940K / 244M
/fs/rwdata/ = 962M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 12G / 54G
Installed Packages
1U5T-14G421-BAM
1U5T-14G421-BBM
1U5T-14G421-BCM
1U5T-14G421-BDM
1U5T-14G421-BEM
1U5T-14G421-BFM
1U5T-14G421-BGM
1U5T-14G421-BHM
1U5T-14G421-BJM
1U5T-14G658-AH
4U5T-14G422-BAM
4U5T-14G422-BBM
4U5T-14G422-BCM
4U5T-14G422-BDM
1U5T-14G424-BP
5U5T-14G391-EM
APIM AsBuilt
DE00: 0A6A019A50023E040082
DE01: 524F010EC20A5C90ACB0CE05
DE02: 0007000000
DE03: 00000C80250102
DE04: 18061810295F
DE05: 20
DE06: 17003300000000A17500005656780088
autoinstall.lst
; SYNC3 Consumer Application Upgrade - Release 3.4.26057 - Only for Nav/EU assemblies.
[SYNCGen3.0_3.4.26057_PRODUCT]
Item1 = HB5T-14G386-VCB
Open1 = SyncMyRide\HB5T-14G386-VCB.tar.gz
Item2 = HB5T-14G386-VHA
Open2 = SyncMyRide\HB5T-14G386-VHA.tar.gz
Item3 = 1U5T-14G424-BP
Open3 = SyncMyRide\1U5T-14G424-BP.tar.gz
Item4 = 1U5T-14G421-BAM
Open4 = SyncMyRide\1U5T-14G421-BAM.tar.gz
Item5 = 1U5T-14G421-BCM
Open5 = SyncMyRide\1U5T-14G421-BCM.tar.gz
Item6 = 1U5T-14G421-BDM
Open6 = SyncMyRide\1U5T-14G421-BDM.tar.gz
Item7 = 1U5T-14G421-BEM
Open7 = SyncMyRide\1U5T-14G421-BEM.tar.gz
Item8 = 1U5T-14G421-BFM
Open8 = SyncMyRide\1U5T-14G421-BFM.tar.gz
Item9 = 1U5T-14G421-BGM
Open9 = SyncMyRide\1U5T-14G421-BGM.tar.gz
Item10 = 1U5T-14G421-BHM
Open10 = SyncMyRide\1U5T-14G421-BHM.tar.gz
[SYNCGen3.0_3.4.26057]
Item3 = 1U5T-14G421-BJM
Open3 = SyncMyRide\1U5T-14G421-BJM.tar.gz
Item4 = 1U5T-14G421-BBM
Open4 = SyncMyRide\1U5T-14G421-BBM.tar.gz
Item5 = 4U5T-14G422-BAM
Open5 = SyncMyRide\4U5T-14G422-BAM.tar.gz
Item6 = 4U5T-14G422-BBM
Open6 = SyncMyRide\4U5T-14G422-BBM.tar.gz
Item7 = 4U5T-14G422-BCM
Open7 = SyncMyRide\4U5T-14G422-BCM.tar.gz
Item8 = 4U5T-14G422-BDM
Open8 = SyncMyRide\4U5T-14G422-BDM.tar.gz
Old SYNC Version: 3.4.21194
New SYNC Version: 3.4.26057
MEM_ERR03
