TCU-KG9T Database
Discussion topic for TCU-KG9T Database
AsBuilt Database Description
The data contained in this database applies to the TCU ****-14G087-** / ****-14G229-** hardware. There may be differences due to vehicle model and region.
Applicable models: KG9T, KT1T.
Alert Configuration Info:
7C=QOS Level=1, Alert Sent Immediately/DRX continues/Connection time not extended, Alert in Roaming Status Enabled, Alert Status Disabled
7D=QOS Level=1, Alert Sent Immediately/DRX continues/Connection time not extended, Alert in Roaming Status Enabled, Alert Status Enabled
Originally published at: TCU-KG9T Database - CyanLabs
