Guys! I appoligise for the Virus warnings however really you have the software manufacturers to blame, there is some software called “Fody Costura” used to embed dll’s in to exe’s to make the installs cleaner, however lots of less accurate software detects the “Embed Code” as a virus as this same software is used by virus makers to hide which DLL files etc they use with their virus. This should now be fixed in 2.2.0.0 releases a few moments ago, note that depending on what launcher version you have you may see 2 update processes, this is completely normal, full changelog as always can be found on Syn3 Updater – CyanLabs at the bottom or directly at https://cyanlabs.net/api/app/Syn3Updater/githubchangelog
Once again, this software is open source, but does require a token to access my API, if you are interested in building from source please let me know and i will provide you with a limited access token.
