Hello, all. Thanks in advance for all replies and help. It is much appreciated.
I have a 2018 F150 Lariat, non-nav. I kept waiting for Ford to update me from 3.0.20204 and fix some problems, but Ford seems to have abandoned 3.0.
2-3 months ago I updated via Syn3 Updater to 3.4.21265. Very easy, took about 10 minutes, no errors. Has functioned well ever since.
Yesterday I decided to update to 3.4.22110. Created USB with Syn3, autoinstall. Got the “updating system software” message, no errors, no reboots. After an hour, I gave up, removed USB. System still on 3.4.21265 and functioning fine.
Today I tried running Interrogator in an effort to determine if I have storage issues, but it kept throwing an error. I’ve tried Interrogator with 2 different factory-bought SanDisk USB drives, same result from both.
I’m very grateful for any and all help in getting me to 22110. Thank you.
Navigation Variant: No
Old SYNC Version: 3.0.20204
New SYNC Version: 3.4.21265
On Interrogator, “The XML file you have selected does not contain a valid ‘ECU Delivery Assembly Number’ therefor Syn3 Updater can not determine if this is a MY20+ APIM or not!”
Syn3 Updater Version: 2.11.1.0
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2022-06-26" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>1FTEW1CG2JKedited</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>5U5T-14G381-EU</d2p1:Response>
</d2p1:DID>
<d2p1:Response>355535542d3134473339312d435000000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>VWAP22ED</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>94:e3:6d:d6:a1:69</d2p1:Response>
</d2p1:DID>
<d2p1:Response>94:e3:6d:d6:a1:6a</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2022-06-26T11:46:30+00:00" RAM="424685568" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/Nuance/" total="465M" available="3.2M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="775M" available="5.8M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="974M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="132M"/>
<d2p1:PartitionHealth type="/fs/images/" total="3.0G" available="1.7G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
