What is your SYNC Region?
North America
Do you have Navigation?
What region is your SYNC APIM?
North America
What was your old SYNC Version?
3.0.20204
What is your new SYNC Version?
3.4.21194
"Error
The XML file you have selected could not be read, please ensure this is the correct fole. If you are sure this file is correct please contact CyanLabs so we can investigate further."
How did you update, Ford Website / CyanLabs Website / Syn3 Updater?
Syn3 Updater
What version of Syn3 Updater did you use?
2.10.3.0 (Stable) -
Yes -
Please paste your log output or provide the URL to your log file belowProcessing: Sync_WVC0B5YG_redated.xml…
(Log files can be found on the root of your USB drive or in %localappdata%\CyanLabs\Syn3Updater\Logs
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2021-08-24" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>redacted</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue="f0031608"/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>5U5T-14G381-ET</d2p1:Response>
</d2p1:DID>
<d2p1:Response>355535542d3134473339312d435000000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>WVC0B5YG</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>a8:1b:6a:08:96:a4</d2p1:Response>
</d2p1:DID>
<d2p1:Response>a8:1b:6a:08:96:a5</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2021-08-24T14:18:15+00:00" RAM="1417015296" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/Nuance/" total="465M" available="3.2M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="775M" available="5.8M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="1022M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="132M"/>
<d2p1:PartitionHealth type="/fs/images/" total="3.0G" available="1.7G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Please provide any further details below
Hello, I recently upgraded my SYNC 3 to version 3.4, and everything is working great. However, when I went ahead to create a new Interrogator Log File with the updated SYNC 3.4, and tried to open/upload the XML file in Syn3Updater, I got the error stated above. I tried to to this several times, re-creating the Interrogator Log XML file several times, but I still got the same error. Thank you for creating such an amazing app, I still can’t believe that this is free. I would happily donate for your efforts.
