What is your SYNC Region? NA
What was your Old SYNC Version? 3.0.20204
What is your current SYNC Version? 3.0.20204
Do you have Navigation? Y
Have you read the documentation at Syn3 Updater - CyanLabs ? Y
Do you have a error message, if so what is it? Y’
Validate: 4U5T-14G421-CCD_1615428361000.TAR.GZ (Failed!, Downloading)
[7/13/2021 4:08:26 PM] Downloading: 4U5T-14G421-CCD_1615428361000.TAR.GZ
PASTE LOG HERE
no issue here, the file failed to download, not much we can do about that.
except it does it on every attempt on that specific file
The snippet of log you have provided shows no issue, it didn’t find a valid file so it started downloading the file… Post a full log
[7/13/2021 6:14:41 PM] Selected Region: NA - Release: Sync 3.4.21098 - Map Version: 2.20 (2020) - NA
[7/13/2021 6:14:41 PM] Install Mode: Auto-Detect (reformat) Forced: False
[7/13/2021 6:14:41 PM] MY20 Protection: Disabled / Not MY20
[7/13/2021 6:14:41 PM] Formatting USB drive
[7/13/2021 6:14:41 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[7/13/2021 6:14:52 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[7/13/2021 6:14:52 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[7/13/2021 6:14:52 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[7/13/2021 6:14:54 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[7/13/2021 6:14:54 PM] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[7/13/2021 6:14:55 PM] Validated: 5U5T-14G391-CN_1615429328000.TAR.GZ (Skipping Download)
[7/13/2021 6:14:55 PM] Checking Existing File: 5U5T-14G381-ES_1619042260000.TAR.GZ
[7/13/2021 6:14:58 PM] Validated: 5U5T-14G381-ES_1619042260000.TAR.GZ (Skipping Download)
[7/13/2021 6:14:58 PM] Checking Existing File: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[7/13/2021 6:15:00 PM] Validated: 4U5T-14G422-CCH_1615429127000.TAR.GZ (Skipping Download)
[7/13/2021 6:15:00 PM] Checking Existing File: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[7/13/2021 6:15:00 PM] Validate: 4U5T-14G422-CBH_1615429039000.TAR.GZ (Failed!, Downloading)
[7/13/2021 6:15:00 PM] Downloading: 4U5T-14G422-CBH_1615429039000.TAR.GZ
seems to only do this only when I attempt to download maps v. 2.20 when I attempt 1.19 (my current version) it says "not enough disk space) but I am using a 32GB MicroSD. Should/can I update to 3.4 without upgrading to maps 2.20 keeping 1.19? would this reduce the space needed? Probably not since this is a re-format??
log file from 1.19 attempt
[7/13/2021 6:34:50 PM] Selected Region: NA - Release: Sync 3.4.21098 - Map Version: 1.19 (2019) - NA
[7/13/2021 6:34:50 PM] Install Mode: Auto-Detect (reformat) Forced: False
[7/13/2021 6:34:50 PM] MY20 Protection: Disabled / Not MY20
[7/13/2021 6:34:50 PM] Formatting USB drive
[7/13/2021 6:34:50 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[7/13/2021 6:36:19 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[7/13/2021 6:36:19 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[7/13/2021 6:36:19 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[7/13/2021 6:36:21 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:21 PM] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[7/13/2021 6:36:23 PM] Validated: 5U5T-14G391-CN_1615429328000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:23 PM] Checking Existing File: 5U5T-14G381-ES_1619042260000.TAR.GZ
[7/13/2021 6:36:26 PM] Validated: 5U5T-14G381-ES_1619042260000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:26 PM] Checking Existing File: 4U5T-14G421-CAC_1580860353000.TAR.GZ
[7/13/2021 6:36:30 PM] Validated: 4U5T-14G421-CAC_1580860353000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:30 PM] Checking Existing File: 4U5T-14G421-CBC_1580860472000.TAR.GZ
[7/13/2021 6:36:33 PM] Validated: 4U5T-14G421-CBC_1580860472000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:33 PM] Checking Existing File: 4U5T-14G421-CCC_1580860555000.TAR.GZ
[7/13/2021 6:36:37 PM] Validated: 4U5T-14G421-CCC_1580860555000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:37 PM] Checking Existing File: 4U5T-14G421-CDC_1580860682000.TAR.GZ
[7/13/2021 6:36:41 PM] Validated: 4U5T-14G421-CDC_1580860682000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:41 PM] Checking Existing File: 4U5T-14G421-CEC_1580860767000.TAR.GZ
[7/13/2021 6:36:44 PM] Validated: 4U5T-14G421-CEC_1580860767000.TAR.GZ (Skipping Download)
[7/13/2021 6:36:44 PM] Checking Existing File: 4U5T-14G421-CFC_1580860863000.TAR.GZ
[7/13/2021 6:36:44 PM] Validate: 4U5T-14G421-CFC_1580860863000.TAR.GZ (Failed!, Downloading)
[7/13/2021 6:36:44 PM] Downloading: 4U5T-14G421-CFC_1580860863000.TAR.GZ
[7/13/2021 6:38:17 PM] Validating: 4U5T-14G421-CFC_1580860863000.TAR.GZ
[7/13/2021 6:38:21 PM] Downloaded: 4U5T-14G421-CFC_1580860863000.TAR.GZ
[7/13/2021 6:38:21 PM] Checking Existing File: 4U5T-14G421-CGC_1580860974000.TAR.GZ
[7/13/2021 6:38:21 PM] Downloading: 4U5T-14G421-CGC_1580860974000.TAR.GZ
Maps and application updates are independent but can be done together. You can keep the NA 1.19 maps and update to Sync 3.4, in your case I recommend 3.4.20351 if you have SiriusXM. If you decide to update the maps, it is much faster to use the reformat method for your 2018 Powerstroke, about 30 minutes vs 60 or more with autoinstall. Since you are on Sync 3.0 now, you will need to reformat to 3.4 anyways.
If you are having issues downloading the maps, you can download them from Software Database - CyanLabs with a browser and place them in the Syn3Updater folder manually, then make the usb with the app.
