I see 2 packages listed in my installation USB that aren’t on the list you provided
MAP_LICENSE 4U5T-14G424-CD
APPS 5U5T-14G381-ET
Yes these are also there, you can see the apps one here
d2p1:Response5U5T-14G381-ET</d2p1:Response>
</d2p1:DID>
The license doesn’t show up afaik
That looks good.
I missed and omitted it…
But the app package is basically sync3, and you can check the version in the about section of Sync3.
About map licence, if navigation works, then it’s ok…
It does not, but will be in the IVSU screen.
On reformat, it is not necessary to place the map license, BUT if you update any of the map files or nav voice files later thru autoinstall it must be installed. You could probably install it separately when that update is done. I always put it in so I don’t have issues later.
