Hi. Can you help me: I updated sync 3.0 to3.4.20xxx by mistake I didn’t select “Navigation” and now navigation doesn’t work. First sync 3.0 and F9 maps. Thank you
Please post in English, this is an English only speaking forum
Hi. Can you help me: I updated sync 3.0 to3.4.20xxx by mistake. I have not selected “Navigation” and now the navigation does not work. First synchronization of maps 3.0 and F9. Thank you
You can use the app to install 3.4 again but with maps. Just make sure that 3.4 is set as your current sync version in the config and select 3.4 with maps. It’ll make a new USB that’ll downgrade you and reformat back to 3.4 with maps installed.
Ok.thanks im try :-):-):-)
