Hello, thanks for reading.
I’m posting this on someone else’s behalf.
He originally had a Sync2 with NAV, and then got the files for a Sync3 NONAV.
This is what he currently has:
JL1T-14G381-AJ versión 2.3.17109
JL7T-14G391-BB versión 2.3.16322
Now he got the files for 3.0 build 19205, but with NAV.
The autoinstall.lst file is the following:
; SYNC3 Consumer Assembly Upgrade - Release 3.0.21 - Only for Nav/TN-RoW assemblies.
[SYNCGen3.0_3.0.19205_PRODUCT]
Item1 = HB5T-14G386-THA
Open1 = SyncMyRide\HB5T-14G386-THA.tar.gz
Item2 = HB5T-14G386-TCB
Open2 = SyncMyRide\HB5T-14G386-TCB.tar.gz
Item3 = HB5T-14G386-AHJ
Open3 = SyncMyRide\HB5T-14G386-AHJ.tar.gz
Item4 = JR3T-14G391-DE
Open4 = SyncMyRide\JR3T-14G391-DE.tar.gz
Item5 = JR3T-14G381-AS
Open5 = SyncMyRide\JR3T-14G381-AS.tar.gz
Item6 = JR3T-14G423-DB
Open6 = SyncMyRide\JR3T-14G423-DB.tar.gz
Item7 = HB5T-14G387-AAB
Open7 = SyncMyRide\HB5T-14G387-AAB.tar.gz
Item8 = GB5T-14G386-AB
Open8 = SyncMyRide\GB5T-14G386-AB.tar.gz
Options = AutoInstall,Delay
So question is can he actually go to Sync3 3.0 NAV again?
Or maybe without NAV (he is willing to do so), maybe commenting something out in autoinstall file…
Thanks!
Yes, why why wouldn’t he be able to. You can’t have maps on a non nav unit though.
He decided to go to 3.4. The thing about nav and nonav is that he actually changed hw in the past, to go from Sync2 to Sync3… This can be closed, thanks.
regana
August 13, 2020, 2:49am
#4
Hola, que significa “Solo para ensamblajes Nav / TN-RoW.”
Tengo un Ford Escape 2.0 año 2017 y no puedo actualizar debido a que no inicia la instalación, la descarga es el archivo JR3T-14G381-AS-PKS con el siguiente autoinstall.lst:
; SYNC3 Consumer Assembly Upgrade - Release 3.0.21 - Only for NonNav/NonEU assemblies.
Item2 = HB5T-14G386-TBB
Open2 = SyncMyRide\HB5T-14G386-TBB.tar.gz
Item3 = GB5T-14G386-SC
Open3 = SyncMyRide\GB5T-14G386-SC.tar.gz
Item4 = JR3T-14G391-BF
Open4 = SyncMyRide\JR3T-14G391-BF.tar.gz
Item1 = HB5T-14G387-AAB
Open1 = SyncMyRide\HB5T-14G387-AAB.tar.gz
Item2 = JR3T-14G381-AS
Open2 = SyncMyRide\JR3T-14G381-AS.tar.gz
Item3 = JR3T-14G423-BB
Open3 = SyncMyRide\JR3T-14G423-BB.tar.gz
Item4 = GB5T-14G386-AB
Open4 = SyncMyRide\GB5T-14G386-AB.tar.gz
¿La pregunta es me sirve el archivo con el autoinstall.lst?
This has nothing to do with my guide or application, use our FordSyncDownloader and update that way.
