Hello, I am trying to downgrade from the latest Sync3.0 into a version that let’s me upgrade it to Sync3.4. The issue i am having is the Syn3 Updater not recognizing my USB. My USB is SANDISK Ultra Dual Drive Luxe 128 GB, exFAT formatted. Thanks for any help!
Old SYNC Version: 3.0.23219
New SYNC Version: 3.0.23219
None
If the updater isn’t seeing it, check your settings and make sure the device is formatted in exFAT.
3.0 is not a downgrade, its a straight reformat to get to 3.4.x
Run the interrogator first to verify that you don’t have the MY2020 IC in the APIM, date of manufacture or the year of the car doesn’t mean you don’t have it.
If you try to reformat and have the MY2020 IC in the APIM you’ll brick it
I had to format it to exFAT earlier because it was FAT32 but now it does say it is exFAT, still cannot see it there though.
On earlier attempts in the other part of the app when I chose the option to upgrade to Sync3.4, it did find it and I could select it but it told me “The file you selected is on hard drive”, it might be relevant.
