aimjustin
(aimjustin)
1
I dont know if i can update my sync to sync 3.4 and i dont sure if my APIM is before 2020 or after 2020. My version is : R5.3.0.1_R18364b .
Old SYNC Version: 3.0
New SYNC Version: 3.0
no message
SaNdMaN
(SaNdMaN)
2
You can’t, that is not Sync 3.
aimjustin
(aimjustin)
3
Can you explain me what is R5.3.0.1_R18364b.
SaNdMaN
(SaNdMaN)
4
Your current Sync version.
aimjustin
(aimjustin)
5
it’s sync 2 or sync 3 or another ?
SaNdMaN
(SaNdMaN)
6
I’ve just said it’s not sync 3, didn’t you read my original reply?.
It’s either 2 or 2.5.
It does not matter, you can’t update to 3.4 since it’s not Sync3.
aimjustin
(aimjustin)
7
how is can upgrade to sync 3 ?
SaNdMaN
(SaNdMaN)
8
Via software, you can’t.
You need to buy hardware, a retrofit upgrade kit.
SaNdMaN
(SaNdMaN)
10
Np, just research before commiting since it’s not plug and play, there’s also programming involved.
Good luck and take care.
aimjustin
(aimjustin)
11
if i real want sync 3 what id the best : change car for newer or retrofit on my car ?
SaNdMaN
(SaNdMaN)
12
The retrofit will be cheaper and if done correctly will work fine.
Now, if you are looking for excuses for a new car, well, that’s another story…
Changing the car is excessive, but that’s up to you.
Look online, you will find plenty of success stories for upgrading.
aimjustin
(aimjustin)
13
if i want use upgrade kit , i need ForScan ?
SaNdMaN
(SaNdMaN)
14
Most likely, yes. But I can’t confirm since it’s outside my scope.
aimjustin
(aimjustin)
15
okay thanks for your help
SaNdMaN
(SaNdMaN)
16
Yw. You are in the EU, so this won’t help.
But you can check as reference, maybe that will help.
aimjustin
(aimjustin)
17
no upgrade kit for my car on the website
system
(system)
Closed
19
