Ford Sync 4 Swap Cameras Dim Now?
1
53
July 4, 2026
SYNC 4 Swap Camera
8
328
July 3, 2026
Update on CarPlay turn-by-turn in IPC?
2
144
May 18, 2026
Hide unsupported usb hub message?
1
55
May 17, 2026
APIM DTC ERRORS
10
216
January 7, 2026
Idle Issues
2
81
December 18, 2025
SYNC 2012 F250 SOUNDS POSSESSED
4
53
September 16, 2025
Lincoln Corsair 2022 PSCM
25
401
August 20, 2025
Sync 1 to Sync 3 upgrade - Reverse camera not working
7
672
May 26, 2025
Enabling Heated Steering Wheel
13
149
December 2, 2024
2012 Focus Titanium DSP module issue
6
322
August 28, 2024
FORD Focus TCU install
15
584
August 23, 2024
I have some issue with error code U0300:00-2B in my Ford Fusion 2017
10
486
August 19, 2024
Problem with TCU replacement
10
441
August 15, 2024
Back Up Camera Zoom feature not working after sync 1 to sync 3.4
1
218
July 14, 2024
CAN bus communication troubles
4
359
July 6, 2024
RSO warning calibration level
5
388
April 15, 2024
Navigation
3
341
February 9, 2024
Running Android Auto and Ford DAB on the same screen?
2
412
September 27, 2023
Semi-Auto Parallel Park Display Issue
7
764
September 5, 2023
Screen went black but turned back on after update from 2.3.17109 to current 3.4.22251
10
821
June 1, 2023
Master reset of sync 3
2
2191
May 16, 2023
Donations
2
300
May 15, 2023
TCU without antenna connector
2
666
February 3, 2023
GPS tracker/black box application for Android
2
584
January 29, 2023
Sync 3 Downgrade from 10.1" Display to 8" Display on 20+ Explorer
16
5818
December 14, 2022
'19 Ecosport Titanium can lane keep be added fairly easy.. '19 Ecosport S upgrade cluster
1
483
December 6, 2022
Interested In Reviewing This Website
5
442
November 8, 2022
Simplest Android Auto on Sync 2
12
29870
August 28, 2022
Current region does not match selected
7
2068
July 15, 2022
