18' F150 - SYNC3 to SYNC4 retrofit, lost Active Park Assist. Can I get it back?
I recently purchased a SYNC3 to SYNC4 retrofit package from Infotainment.com where they replaced the APIM, ACM, and 12” screen. One of the items that stopped working was my Active Park Assist. I believe the problem is due to the APIM configuration and I have had no luck in getting the PAM (Parking AID Module) to display anything on the screen. Does anyone have experience in re-enabling Park Assist after upgrading from SYNC3 to SYNC4? Thanks!
Do they not offer support when you purchase something from them? Seems odd they would claim this would work and than they dont help you get it working.
They never claimed that I would maintain this functionality, but they also didn’t offer any assistance in restoring it. I’ve tried to get support regarding a few other issues and have been severely disappointed.
They also say there will be updates in the future but they are totally incorrect on that. There will never be updates since they are VIN specific.
Sorry they are not helping you.
Can you post your Sync 3 and 4 asbuilt?
The issue is likely an APIM asbuilt issue. I’m sure they asked for your VIN to program the Sync 4 APIM…7D0-08-01 xxxx xxx* xx–
If you made changes to the PAM, restore the asbuilt using your OEM file. That’s not the issue.
I didn’t make any changes to the PAM. Below is the APIM asbuilt that came with the SYNC4 module:
;Block 1
7D0G1G1A0810802D2D6
7D0G1G20000D62C08E4
7D0G1G30000000000DB
7D0G1G402C08020003E
;Block 2
7D0G2G10004100A07FF
7D0G2G2000000C808AB
7D0G2G30000000000DC
;Block 3
7D0G3G155530203038B
7D0G3G21000320E012D
7D0G3G30000000000DD
;Block 4
7D0G4G1052400000005
;Block 5
7D0G5G10102000000E0
7D0G5G2000300E5D89E
7D0G5G34BE700000011
;Block 6
7D0G6G11A681A68381A
7D0G6G2A483
;Block 7
7D0G7G1460033000058
7D0G7G20000029A007C
7D0G7G300565692001F
7D0G7G4C8AA
;Block 8
7D0G8G1400000000020
7D0G8G20000000000E1
;Block 9
7D0G9G10000000000E1
7D0G9G20000000000E2
7D0G9G30000000000E3
7D0G9G40000000000E4
7D0G9G50000000000E5
;Block 10
7D0GAG10000000000E8
7D0GAG20000000000E9
7D0GAG30000000000EA
7D0GAG40000000000EB
7D0GAG50000000000EC
Do you have your Sync 3 asbuilt also?
Sorry, here is the SYNC3 asbuilt:
;Block 1
7D0G1G1AA2A010304B5
7D0G1G202A900048A13
;Block 2
7D0G2G155530103F47A
7D0G2G20242900000AF
7D0G2G3400521
;Block 3
7D0G3G10000010300DF
;Block 4
7D0G4G1010014000EFF
7D0G4G20008E5
;Block 5
7D0G5G11A681A683819
7D0G5G2A482
;Block 6
7D0G6G1805E
;Block 7
7D0G7G1460033000058
7D0G7G20000029A007C
7D0G7G300565692001F
7D0G7G4C8AA
;Block 8
7D0G8G10000000000E0
7D0G8G20000000000E1
Thanks.
APA is not enabled in the Sync 4 asbuilt. You can enable APA with FORScan…
Your Sync 3 asbuilt has APA active…
7D0G4G20008E5
08=APA Lite (SAPP) (10 or less Sensors) (Parallel Park Only)
You will need to activate APA in Sync 4…
7D0G8G1400000000020
to
7D0G8G1004000080028
Is this a Lariat?
Let me go thru these, I’ll see what else is missing.
Yes, it is a Lariat. I’ll give that change a try and let you know.
I went thru the rest of the Sync 4 asbuilt and didn’t find anything wrong, based on your vehicle, 2018 F-150 Lariat 4WD. All of the vehicle specific data was correct, just copied from the Sync 3 asbuilt. As far as I can tell from the asbuilts, everything should work. If you find any issues give me a shout.
Keep in mind that you will never receive Sync 4 app updates or map updates for this system. Ford has these systems VIN associated with the APIM ESN, and your 2018 TCU does not support OTA updates.
You stated that you have a new ACM module also. Did they supply a wire harness for this kit? Your 2018 F-150 would not have the wiring installed to support the newer SiriusXM X40 or newer radios. Interested to know if they supplied a harness and the part numbers of the APIM and ACM.
Unfortunately, enabling APA via Forscan did not bring anything new to the display. I can tell that the PAM is still working though because it still chimes when I push the button for parallel parking assistance and it attempts to guide me via chimes. I just don’t feel comfortable without having something on the display telling me when to do what.
When I received the new ACM, it did come with a new harness. The part number for the new ACM (from Forscan) is KL3T-18D832-FH and the APIM part number is MU5T-14G670-PNN. Thanks for all your help!
Does the rear camera display in reverse?
You have 360 view cameras, right?
Does the 360 view come up with the hard button toggle or reverse?
Yes to all of those.
I did add ACC w/Stop & Go back when I had SYNC3. I wonder if that changes the APA type since I now have some additional sensing equipment (CADS, newer IPMA)??
