2015 Mustang Mirror clicking with memory recall
My problem for years is that the driver and passenger mirrors will click when the memory recall is initiated with a different driver.
My 2015 Mustang has seat and mirror memory settings for 3 different drivers that will set the seat and mirror positions when recalled. When that happens, the mirrors will adjust and start clicking as they get to the extreme of range of motion. If I manually intervene with the electronic mirror control it will stop the clicking. Then you can recall the setting again and it will adjust the mirrors without clicking.
According to Ford, updating the passenger and driver door modules to latest calibration and strategy should stop the mirror clicking when the memory setting changes for a different driver. Forscan only has one but not the other.
So I am needing the latest file set as Forscan only has one but not the other. The follow are, according to Forscan, the latest calibration and strategy for each module.
PDM
Calibration: FR3T-14B533-AC
Strategy: FR3T-14C108-AC
DDM
Calibration: FR3T-14B531-AC
Strategy: FR3T-14C064-AC
Any help in obtaining the files would be appreciated. Don’t mind buying a pass for Ford’s website but would like to know if the files are available there first.
Thank you.
My Expedition will do this also. Pretty sure I updated my modules but it still does it.
I have that occasionally on my 2015 F-150, with 2019/2020 firmware in the mirror modules. I usually just press the memory button and it stops and sets the mirror correctly. No DTC’s.
I have seen this on Ford rental cars and others. Seems to be a feature…
SSM 49217 - Mirror click.pdf (113.7 KB)
This is Calibration Level, not the typical Calibration file…
You only need to change the Strategy files.
I have not been able to locate them…
DDM - Drivers Door Module
Part number (F113): FR3T-14B531-AB
Cal Level: FR3T-14B531-AC
Hardware Number: FR3T-14F142-AB
Secondary Boot Loader: FR3T-14C067-AA
Strategy (F188): FR3T-14C064-AC
ECU Configuration (F10A): FR3T-14C637-AC
PDM - Passengers Door Control Unit
Part number (F113): FR3T-14B533-AB
Cal Level: FR3T-14B533-AC
Hardware Number: FR3T-14F144-AB
Secondary Boot Loader: FR3T-14C111-AA
Strategy (F188): FR3T-14C108-AC
ECU Configuration (F10A): FR3T-14C639-AC
However, all these did download from - FordServiceInfo.Com
Cal Level: FR3T-14B531-AB
Strategy (F188): FR3T-14C064-AB
Cal Level: FR3T-14B533-AB
Strategy (F188): FR3T-14C108-AB
The fact that the previous versions downloaded and the -AC cal level does not indicates the files were for demand only for the SSM and never published as production.
I created DDM/PDM tags…
So if I went to the dealer with the issue, they could update it.
If I have access to FDRS (fleet access not dealer) , could I do the update?
I would expect you could get access to the files that way, not sure though.
LOL, no kidding.
