2016 f150 dash screen staying live after shutdown
2016 f150 xlt sync 3
sync3 build 23219
gracenote version 1.1.1.1139 (na-0010)
navigation maps version NA 1 14
master reset no avail
Bought as a used truck dead battery,
new batttery, 3.5 amp draw
pull fuse 32 in bcm, poweres down screen, reinsert fuse powers up screen ford logo, then back to black and no power draw until key is cycled, no other issue until shut down and screen stays live, pull fuse repeat evrytime i drive the truck, theres no return on the truck its mine i own it i want to fix it.
apim part #GL3T-14G370-KL
i have Forscan
in forscan i can change the apim asbuilt 7D0-06-01: x1xx-xx
save, cycle key and it will not stay
i do not have UCDS and dont even know what it is or how to get it (im in Canada)
i want to rectify the problem before trying to upload something that may not work
Old SYNC Version: 1.1.11139
New SYNC Version: 1.1.11139
no error messages
In ForScan go to Asbuilt Config mode for the APIM, click on load from factory, then write all even if it states “no changes”
This should take you back to factory.
After that pull the battery cable for ~35 minutes to force a full cold reboot of all the modules.
unfortunatley no luck…
Post your APIM AB here.
That is the APIM assembly number, but cross references to GL3T-14G371-CFC. This is a Gen 1 APIM that frequently fail in this manner. You could run the Interrogator Utility in the Syn3 Updater and see if there is an issue or look in FORScan for DTC’s.
This just changes the Illumination Gateway to the wrong value for your vehicle.
Run the Interrogator Utility in the Syn3 Updater and post the XML here if it will complete.
