Easy, Just de-pin it and solder it. Than reinsert and your golden.
That’s an idea, I’m just not sure if the connector is serviceable. The wires come out at a 90 deg angle and I can’t tell if the connector comes apart
It comes apart, the 90° shell comes off, pull the face clip, pins come out the face not the back.
You probally have more wire than you relize once you take the 90deg shell off.
Do I unlock from the front as well? I got the sleeve off and some connections look larger than others and I’d even say it’s from where I put my lead in too far. Anyway, just curious how the pin is “locked” in there. Trying not to break it. Any more than I’ve already broken it lol
There is a plastic pin that come down into the metal pin. You have to stick a needle or pin tool in there to release it. I use a 90deg pick when I do it. You will also need to remove the plastic pin holder. Just remember where it goes in the plug so just do 1 at a time.
Should only be 1 size pin in the whole C2383 54pin connecter.
There are only 26 “slots” in this one, it’s the smaller one that plugs into the FCIM. I was trying to understand if the “lock” is released from the wire end or from the termination end since he said they come out the front. That made me thing maybe the lock is accessed from the rear of the connector, opposite of the terminal.
The lock is at the pin, little plastic nub drops down inside of it to lock it
So I realized last night that I’m not positive it’s a loose connection altho I suppose it could be both. If I plug it in and put some slight pressure sideways on the connector, the back lights will come on, but they go right back off even while I’m holding that pressure. I did it a few times and it seems as this the lights stay on for the same amount of time each time, let’s say half a second. that made me wonder if it’s a matter of the handshake not being right and if so, is there a way to figure that out with FORScan? I really just wanna light it on fire at this point lol.
Sounds more like maybe broken solder joint on the FCIM.
Parts yards can be a little rough pulling things, exactly what is wrong with the original FCIM?
Initially the air would only come out the vent at the windshield no matter which vent/mode you selected, like it was stuck in defrost mode. The indicator lights would light up (for all the other vents) when selected but it was like the damper that controls where the air flow goes was stuck. I replaced the actuator on the drivers side. That fixed it, although the air coming out of the vents was quite as cold as you would expect so I checked the charge and it was perfect. I chalked it up to 10 years old and maybe leaks in the ducting. I never thot to check the heat bc now the air came out of all of the vents. Summer passes and she went to put the heat on one morning and no heat. Plenty of air out of any vent you chose but no heat. This is the point when I read about how the actuator actually works. The actuator on the passenger side I think was stuck slightly open to the heat mode and that’s why the ac never quite got cold enough. Anyway, I measured 13V on the feedback wire from the actuator to the module at the midpoint temp setting and AI said the reference and feedback wires should never see that much voltage so it made sense that a circuit on the module itself had shorted.
Or AI was wrong.
AI uses what is called a Large Language Model, so it pulls things from various sources that may or may not be correct because it doesn’t really understand context. So what it gens out could be part MY2013 Fusion (which was a 1 off year), part MY2019 Fusion and part MY2010 Fusion, hence the reason that there’s a disclaimer on this site about people following AI instructions using the updater rather than the actual documentation.
Best bet for troubleshooting is using getting a subscription to a site like Alldata.
Absolutely agree 100%. It wasn’t AI from this site, it was just Gemini or whatever google’s version is. I try and think of AI like the librarian sort of. It can provide hundreds of sources but you still have to sift thru them and tie things together which like you said, it can’t do, but it kind of made sense in my head that it’s a 5V system (for lack of a better understanding or way to describe it) and I see line voltage. That’s why I eventually came here to try and get some real world experience from ppl who do this stuff all the time. I’m not complaining, just learning or trying to anyway. I normally learn things the hard way obviously and that’s ok and that’s what I meant in the original post by “I underestimated the complexity of the control system”. So I’m curious, what are your thoughts? What would be your next move?
