2018 MUSTANG SYNC 3
2018 MUSTANG SYNC 3 3.0 17276 BUILD Apim intermittantly operates. When it does it will work unitl the ignition is cycled or a factory reset in the SYNC module is performed.
APIM JR3T-14G371-BED
Attempted software update through ford FDRS and received error code 8033: JR3T-14G371-AJ SHOULD JR3T-14G381-AY. Before attemtping the update Ford PTS showed software last installed in 2017
Tried SYNC 3 updater in auto mode and received INSTL_ERR12 on Sync screen.
Is it safe to assume that the APIM needs to be replaced?
Navigation Variant: No Nav
Old SYNC Version: 3.0 17276
New SYNC Version: 3.0 17276
INSTL_ERR12 CYAN
8033 Official Ford
I inadvertently listed this vehicle has Nav, it does not,
I corrected that for you…
INSTL_ERR12
You might have an APIM that has hardware issues. There is no known workaround for this one.
See if you can perform a Master Reset and run the RWData Cleaner in the Syn3 Updater. If not, you’ll probably have to replace the APIM.
Thanks for your input
