Hello, I own a 2024 Ranger Raptor and I am curious if I can modify the camera angles/views on Forscan. I don’t like the way Ford has engineered the camera software since it mostly focuses on unnecessary angles, particularly the side views. Has anyone discovered a way to modify the camera views for the rear side view button and angle them facing the front wheels instead? Thank you.
You can do it but….. No one knows what values do what so your running in the dark on this one.
Probably have better luck at F150Forum or https://www.ranger6g.com/
Great, so I assume its possible just thru Forscan if we technically know the values?
Exactly. I played with it a bit with some values that F150Chief gave me and it made mine worse. If you figure out what lines do what than please share. It’s a pretty big undertaking as there are so many values.
I’ll try to check what values do what and will try to update you guys, still waiting on my new cable to arrive. Just curious, what values were given to you?
It was more just sharing AB settings without knowing what they were. Our 2 rigs were to far apart for it to help me.
