Hi, I messed with something in Forscan and now the remote doesn’t work. Could someone help me? Thanks
Restore the backup you made before changing things.
If you didn’t take a backup and the car is stock, retrieve the factory asbuilt from Ford with your VIN and apply it.
Thanks, but I don’t know how to do it
Try setting your country in https://www.motorcraftservice.com/SetCountry and then going to https://www.motorcraftservice.com/asbuilt
I downloaded the file, and it tells me to put it in
c:\Program Files\Ford Motor Company\Calibration Files. So far, it’s fine, but what do I have to do next? Sorry for the clumsiness.
Module in AsBuilt config.
Load from file and pick the AB file you downloaded, this ONLY changes the config on the module you’re working on. It doesn’t return the entire car back to factory.
I touched something in Forscan, but I don’t remember what it was. If I found it, I would activate it again and the remote would work again.
