ACM missing calibration data#2 DTC U201B
Block 9 is probably presets, you can’t write those on some ACM’s. 5A worked as it should…
Im able to save on preset 2 and 3. preset 1 is however not possible. is there any option to enable the preset setting on sync?
That would be an ACM issue. Make sure that Sync and the ACM have the same settings for number of presets in FORScan. Set them both to 6 presets.
