I just replaced my ACM(ebay) with same model/part numbers hoping to Plug and Play. No cigars. I do have FORscan and compatible cord, but I just learned about forscan last week. Ive been playing around with the asbuilt files, resetting this and that. Nothing is working. A total newbie. If there is anyone Bored enough to help, PLEASE!
Interface:
Type: FTDI #1:D37XANI2, 3000000 bps
Adapter: vLinker FS v2.2.92 MIC3322 V2.0.92 (ELM327 v2.2)
Min.delay: 1 ms ( Excellent)
Errors: None
Vehicle:
Model: Ford Fusion
Engine: EcoBoost Gasoline Turbocharged Direct Injection
Capacity: 2.0L
Year: 2016
Generation: 2016 MY
Fuel: Gasoline
Transmission gear: Automatic
SYNC version: SYNC 1.1
VIN: 3FA6P0T95GR284855
PCM - Powertrain Control Module
Part number: GS7A-12A650-LC
Calibration level: GS7A-12A650-LE
Strategy : GS7A-14C204-LE
Hardware type: FJ5A-12B684-AA
Total Distance: 246482.0 km
OBDII - On Board Diagnostic II
Part number: GG1T-14D212-AC
Calibration level: GG1T-14D212-AD
Strategy : EE8T-14D205-AC
BdyCM - Body Control Module
Part number: FU5T-14B476-DAL
Calibration level: FU5T-14B476-DAL (latest known: FU5T-14B476-DAR)
Strategy : FU5T-14C184-AAJ
FCIM - Front Controls Interface Module
Part number: GS7T-18E243-EC
Calibration level: GS7T-18E243-EC
Strategy : GS7T-14G130-BB
Calibration: GS7T-14G131-BB
FCDIM - Front Control/Display Interface Module
Part number: ES7T-18B955-CB
Calibration level: ES7T-18B955-CB
Strategy : ES7T-14D358-CB
Calibration: ES7T-14D359-CB
OCS - Occupant Classification System Module
Part number: GS73-603B16-AA
Calibration level: GS73-603B16-AA
Strategy : GS73-14F595-AA
Calibration: GS73-14F596-AA
ABS - Antilock braking system
Part number: EG9C-2C219-AE
Calibration level: EG9C-2C219-AE (latest known: EG9C-2C219-AJ)
Strategy : EG9C-2D053-BE
RTM - Radio Transceiver Module
Part number: FL3T-15K619-AB
Calibration level: FL3T-15K619-AB (latest known: FL3T-15K619-AC)
Strategy : FL3T-14G090-AB
PDM - Passengers Door Control Unit
Part number: DG9T-14B533-AL
Calibration level: DG9T-14B533-AL (latest known: DG9T-14B533-XB)
Strategy : DG9T-14C108-AK
DDM - Drivers Door Module
Part number: DG9T-14B531-CG
Calibration level: DG9T-14B531-CG
Strategy : DG9T-14C064-AZ
RCM - Restraint Control Module
Part number: ES7T-14B321-AA
Calibration level: ES7T-14B321-AA
Strategy : DS7T-14C028-CA
Calibration: ES7T-14C098-AA
PSCM - Power Steering Control Module
Part number: F1GC-3F964-AA
Calibration level: F1GC-3F964-AA
Strategy : F1GC-14D003-AA
VIN: 00000000000000000
Odometer: 246480.0 km
SCCM - Steering Column Control Module
Part number: EG9T-3F944-AE
Calibration level: EG9T-3F944-AE
Strategy : DG9T-14C579-AM
IPC - Instrument Panel Control Module
Part number: GS7T-10849-EA
Calibration level: GS7T-10849-EA (latest known: GS7T-10849-EB)
Strategy : GS7T-14C026-CA
Calibration: GS7T-14C088-CA
Odometer: 246482.0 km
GWM - Gateway Module A
Part number: GG9T-14F642-AB
Calibration level: GG9T-14F642-AB
Strategy : GG9T-14F530-AB
GPSM - Global Positioning System Module
Part number: DE8T-19H463-EA
Calibration level: DE8T-19H463-EA
Strategy : DE8T-14F055-DC
===PCM DTC P0012:00-64===
Code: P0012 - ‘A’ Camshaft Position Timing - Over-Retarded (Bank 1)
Status (-64):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Powertrain Control Module
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 238170921 s (Sat Jun 17 23:39:05 2023) - Event time
-TOTAL_DISTANCE: 246117 km - Total Distance
-FUELSYS: Closed Loop - Fuel System Status (Open/Closed Loop)
-LOAD: 62.35 % - Calculated Load Value
-ECT: 88 °C - Engine coolant temperature
-SHRTFT1: 3.13 % - Short term fuel trim 1
-LONGFT1: -0.78 % - Long term fuel trim 1
-MAP: 160.0 kPa - Manifold absolute pressure sensor
-RPM: 2673 1/min - Engine Revolutions Per Minute
-VSS: 89.0 km/h - Vehicle Speed
-SPARKADV: 12.50 ° - Spark Advance
-IAT: 31 °C - Intake Air Temperature
-RUNTM: 1334 s - Time Since Engine Start
-EVAP_PCT: 96.08 % - Commanded Evaporative Purge
-FLI: 31.37 % - Fuel Level
-FTP_H20: -2 - Fuel Tank Pressure displayed as inches of water
-BARO: 97.0 kPa - Barometric pressure
-VPWR: 13.39 V - Control Module Voltage
-TP_REL: 58.04 % - Relative Throttle Position
-TAC_PCT: 74.90 % - Commanded Throttle Actuator Control
-RPMDSD: 750 1/min - Desired Idle Speed RPM
-O2S12: 0.61 V - Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 2)
-TQ_CNTRL: None Requested - Torque Control Requested
-APP_FLT: No Fault - Accelerator Pedal Position Sensor Status
-CHT_F: No Fault - Cylinder Head Temperature Sensor Status
-CHTIL: Off - Cylinder Head Temperature Indicator Lamp
-ECT_F: No Fault - Engine Coolant Temperature Status
-ETC_TRIM_LRN: No - Throttle Angle Offset has Learned
-IAT_F: No Fault - Inlet Air Temperature Sensor Status
-MISFIRE: No - Engine Misfire currently detected
-TP_F: No Fault - Throttle Position Sensor Status
-MP_LRN: Yes - Misfire Profile Correction Learned
-MAF_F: No Fault - Mass Air Flow Sensor Status
-MAP_F: No Fault - Manifold Absolute Pressure Sensor Status
-OTS_STAT: Enabled - One-Touch Start Status
-APP1: 2.05 V - Accelerator pedal position sensor 1
-APP2: 1.02 V - Accelerator pedal position sensor 2
-TP1: 1.63 V - Throttle Position Sensor 1
-TP2: 3.39 V - Throttle Position Sensor 2
-GEAR: 5 - Gear Commanded
-GEAR_OSC: 5 - Gear Command by Output State Control
-TSS_SRC: 2438 1/min - Actual Turbine Shaft Speed
-OSS_SRC: 2440 1/min - Actual Output Shaft Speed
-TFT: 94 °C - Transmission Fluid Temperature
-TR: Drive/OverDrive - Transmission range
===END PCM DTC P0012:00-64===
===OBDII DTC P0012-P===
Status (-50):
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0012-P===
===APIM DTC U0257:00-28===
Code: U0257 - Lost Communication With Front Controls / Display Interface Module
Status (-28):
- Previously Set DTC - Not Present at Time of Request
===END APIM DTC U0257:00-28===
===BdyCM DTC U0256:87-08===
Code: U0256 - Lost Communication With Front Controls Interface Module ‘A’
Additional Fault Symptom (:87):
- Missing Message
Status (-08):
Module: Body Control Module
===END BdyCM DTC U0256:87-08===
===BdyCM DTC U0184:87-08===
Code: U0184 - Lost Communication With Radio
- Missing Message
Status (-08):
===END BdyCM DTC U0184:87-08===
===FCIM DTC None===
Successful DTC reading, no error codes found
Module: Front Controls Interface Module
===END FCIM DTC None===
===FCDIM DTC None===
Module: Front Control/Display Interface Module
===END FCDIM DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===ABS DTC B1111:53-20===
Code: B1111 - Electric Park Brake Enable
Additional Fault Symptom (:53):
- Deactivated
Status (-20):
Module: Antilock braking system
Freeze Frame #1:
-EVENT_TIME: 106191550 s (Fri Apr 12 10:42:55 2019) - Event time
-TOTAL_DISTANCE: 184386 km - Total Distance
-MODULE_VOLTAGE: 12.0 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 27 °C - Outside temperature
-POWER_MODE: Ignition on power mode - Power Mode Status
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Inactive - Hydraulic Pump State
-ECU_POWER_SUPPLY: 12.0 V - ECU Power Supply Voltage
-VSS: 0.0 km/h - Vehicle Speed
===END ABS DTC B1111:53-20===
===ABS DTC U3003:16-60===
Code: U3003 - Battery Voltage
Additional Fault Symptom (:16):
- Circuit Voltage Below Threshold
Status (-60):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 128987596 s (Wed Jan 01 05:57:01 2020) - Event time
-MODULE_VOLTAGE: 8.3 V - Control Module Voltage
-POWER_MODE: PM_Key_out - Power Mode Status
-ECU_POWER_SUPPLY: 8.3 V - ECU Power Supply Voltage
===END ABS DTC U3003:16-60===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===PDM DTC C1B15:15-0A===
Code: C1B15 - Sensor Supply Voltage -B-
Additional Fault Symptom (:15):
- Circuit Short To Battery Or Open
Status (-0A):
- DTC Present at Time of Request
Module: Passengers Door Control Unit
===END PDM DTC C1B15:15-0A===
===PDM DTC U0208:00-0A===
Code: U0208 - Lost Communication With Seat Control Module A
Status (-0A):
===END PDM DTC U0208:00-0A===
===PDM DTC B1C15:15-48===
Code: B1C15 - Passenger Up/Down Mirror Motor Feedback
Status (-48):
- Test not complete
===END PDM DTC B1C15:15-48===
===PDM DTC B1C16:15-48===
Code: B1C16 - Passenger Left/Right Mirror Motor Feedback
Status (-48):
- Test not complete
===END PDM DTC B1C16:15-48===
===DDM DTC None===
Module: Drivers Door Module
===END DDM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC U0184:00-0A===
Status (-0A):
Module: Instrument Panel Control Module
===END IPC DTC U0184:00-0A===
===IPC DTC U0557:82-08===
Code: U0557 - Invalid Data Received From Front Controls Interface Module ‘A’
Additional Fault Symptom (:82):
- Alive/Sequence Counter Incorrect/Not Updated
Status (-08):
===END IPC DTC U0557:82-08===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===GPSM DTC None===
Module: Global Positioning System Module
===END GPSM DTC None===
