ACM U2101 DTC
Hello,
I have installed an ACM with DAB in my Focus MK3 FL, when programming the configuration of my original ACM I got the DTC U2101, I can’t delete it, but everything works. When I try to reload the original configuration with UCDS from the replacement module ACM with DAB, I also get the error code U2101.
Can anyone tell me how to delete the DTC U2101?
Have a read here:-
I only have the DTC U2101 …
As per the link above…
The ACM supports DAB. Here is the part number of the ACM F1BT-18C815-LR. Under Forscan ACm AsBuild I only have one line 7D0-01-01 where it says: 0232 Restore Write, I don’t have any more lines.
Get off the DAB thing. When you put a new ACM in that is newer or older than calibrations can be different and that can change your AB settings. Like what has been said your configuration is wrong. Either fix it or leave it be.
