Activate some options
Hello,
Is it possible to activate certain options such as panel recognition and "driver alert?
The hardware is present.
Same for ANC, can we activate it?
Thanks
FORD KUGA VIGNALE (Europe) with official SYNC 3.4.23188 and MAP F11
Old SYNC Version: 3.4.22251
Depends on the calibration/firmware/hardware present in the car.
As an example the rear seat minder on Sync 3.4 requires that the APIM have a calibration of -EK or higher, you can enable it in the APIM but it doesn’t work on a lower level.
ANC is active noise control (not cancellation) it requires a DACMC, compatible DSP and the required microphones, ForScan will more than likely not pick it up as the 2013-2019 Kuga never had it from the factory.
It is a 2023 KUGA. For ANC there is a picture. I don’t know if it is that and if it is working.
Thanks for your reply
That’s the microphone for the bluetooth cell & Sync voice functions.
The ANC mics are 25mm microphones on the headliner close to the B pillars and in the center of the back seat.
There is a 25 mm microphone on the head driver.
You’re missing the others as well as the ACM with the builtin DACMC.
You don’t have the required components, keep in mind that with the HEV/PHEV the system is used to add noise to cover “unique” sounds from the CVT, on models like the Mustang/Focus ST/Fusion Sport its used it add fake engine noise when accelerating.
The system won’t make the cabin any quieter, this isn’t automatic noise cancellation like you would have with a set of Bose noise cancelling headphones.
Some say that the ANC is installed on a model identical to mine. Can we with Forscan know if the option is present because it is very difficult to know if the ANC works.
For the recognition of the panels and the driver alert, I saw some who managed to activate these options, but I do not know the details to do it.
Is the vehicle a hybrid or PHEV?
What trim is the vehicle?
You probably want to spend some time with this forum.
https://www.kugaownersclub.co.uk/
It is a PHEV VIGNALE.
Then its already active.
There’s are no controls for it, it is totally driven by the PCM, ACM & DSP.
As stated above, the purpose isn’t to make the cabin quieter, its to hide certain noises generated by the power train.
If you wish to quiet the cabin down I would suggest sourcing the acoustic front door glass, in most markets it was removed from the Escape/Kuga after the 2020 model year.
Ok thanks for ANC.
And for the recognition of the panels and the driver alert, I saw some who managed to activate these options, but I do not know the details to do it. I has no these options, it was a pack.
I assume you’re referring to traffic signs.
Here in the US on the MY2021+ Escapes enabling this is actually in the option menus for the APIM and the cluster (HUD also if you have that), its not a ForScan item, you have to enable it on the APIM before you can enable it on the cluster and HUD.
If you don’t have the option, there’s a write up on fordescape.org by 360Alaska to do this which is written around Sync3.
Thanks
I find some informations.
For these modules:
APIM - Modulo interfaccia protocollo accessori
Part number: NU5T-14G371-GAA
Calibration level: NU5T-14G371-GAC
Strategia : 1U5T-14G374-EL
Calibrazione: 1U5T-14G375-HA
IPC - Quadro strumenti del cruscotto
Part number: NV4T-10849-DGD
Calibration level: NV4T-10849-DGD
Strategia : NV4T-14C026-AD
Calibrazione: NV4T-14C088-AD
IPMA - Modulo elaborazione immagini A
Part number: LV4T-19H406-CF
Calibration level: LV4T-19H406-CF
Strategia : LV4T-14F397-CF
Calibrazione: LV4T-14F398-CF
My modules
APIM - Module d’interface de protocole des accessoires
Numéro de pièce: NU5T-14G371-GAF
Calibration level: NU5T-14G371-GAJ
Strategie: 1U5T-14G374-EM
Calibration: 1U5T-14G375-HA
IPC - Combiné des instruments dans tableau de bord
Numéro de pièce: NV4T-10849-DJD
Calibration level: NV4T-10849-DJD
Strategie: NV4T-14C026-AD
Calibration: NV4T-14C088-AD
IPMA - Module de traitement d’image A
Numéro de pièce: LV4T-19H406-CF
Strategie: LV4T-14F397-CF
Calibration: LV4T-14F398-CF
But how to find corresponding activation values ​​for forscan in hexadecimal ?
You mean all these listed on here?
AsBuilt Databases - CyanLabs
Just because you can enable stuff does not mean it will work. Most the time there is hardware that needs to be present for that.
In fact, it is to activate TSR: recognition of road signs, with indication on the instrument panel (limits + no overtaking)
WWA: wrong way alert, recognition and warning in case you take a road in the forbidden direction (e.g. ramp for entering the motorway)
DAS: driver alert security, monitoring of driver attention by analyzing driving style.
I think the only thing missing are the 4 side sensors and the parking camera in front in the grille.
It is from here but impossible to register without pay.
https://forscan.org/forum/viewtopic.php?p=79504#p79504
It is possible to fimd values for APIM.
But for IPC and IPMA, the database stops at the year 2020 or 2019
The IPMA is also a minefield when it comes to making changes.
Anything beyond single bit changes (eg even loading in the factory AB) wipes out the module calibration and requires a re-calibration sequence to be run before things like adaptive cruise and pre-collision braking work correctly.
Anything you touch when you make mods you do at your own risk, if it goes sideways its your fault, not Ford’s or anyone else’s.
