Hi, after updating the modules (IPC;RCM), with FORscan, on a 2016 kuga. I encountered incomplete initial configuration errors. I ask for help to solve the problem. Thank you.
Reset the modules with FORScan. Also, compare the asbuilt data from before and after the updates and see if there is any differences. You will likely have to reload the asbuilts, and should do so, after any firmware updates.
thank you very much F150
very useful advice
