Ambient lighting colour change using touch screen
hello,
ive been doing a bit of research. I’m trying to change the ambient lighting color, using the touch screen. its not an option on the focus rs, stays red, but i would like to have this feature. i’ve seen were you have to change a certain digit in the as-built information to get a “specific” color but im looking to be able to change to different colors going through sync. i was able to activate the Amber Lighting option in sync, but unclear on what to change in BCM through as-built. i keep seeing different settings and what to change them too. wondering if anyone has been successful in making this happen. saw a youtube video were it was done but did not explain or do a tutorial on how he did it. thank you in advanced.
You have a CEGA 1.2 network so I belive this is the AB database for your BCM that you would want.
BCM (2011-2019) Database - CyanLabs
More than likely you can do this assuming you have the correct wiring and LED’s to make it happen. Just need to make the change in the BCM and APIM.
