Another Modem Upgrade 2020 Fusion Energi
Well, if the dealer orders it for you they will order the correct one based off the original CSP as it has the instruction for ordering.
Getting a used unit raises the problem of the dealer techs not being able to get the unit into factory mode as IDS doesn’t have the ability without them opening a ticket with the hot line and a Ford corp. tech putting IDS in engineering mode.
Used unit HS7T-14G229-** from a Canadian 2017/2018 Fusion will work, they would need to update the calibration to -*M. My experience with IDS and used H series units is that if it;s below -*J the unit has to be brought to -*J first before IDS will offer-xM.
