I think the unit will be left at the limit for future package processing, usually you need 1.7 GB of free space to get things going. Personally, I would not install another map without making room first, or leaving a way so that you could free up maps if needed.
Good day and good to hear from you. My car is a Fusion 2017 and the APIM is stock so itâs not a MY20. I do need voice package for navigation because I find it better to listen than look into the screen when driving so in this case I guess I will just leave the current map and voice package I have and use Google maps when I am in central EU.
Out of curiosity, how to free up space? Is it as simple as just disabling voice package during the download process for the update or even simply leaving out the voice package when generating the map cutdown license?
Please ignore âAPIM Model: Unknownâ after updating from sync 3.0 to 3.4 my apim lost itâs model number and asBuilt says blank but that doesnât affect anything. Tried to fix it via forscan but it doesnât work so just ignore that.
Thatâs the list of all packages installed and the memory allocation
You could try either going to an earlier or latest 3.4âŚ
Ok, the big voice file is for nav, so nothing to do there. You could remove gracenotes and shrink the voice package if more space is needed in the future. Also you could downgrade to 3.3 to then reformar the unit.
I think you could try installing the map you want, I believe there are some plan bâŚ
Thank you so much for the advice man. I appreciate it and I will try to experiment, I have already faced the red screen before so I am more calmer doing this.
Btw sorry for chatting about this in that thread specifically about new map updates. I will pay attention to the chat rule better next time . Cheers
Good day, btw we might want to update this info because this part causes problems in some cars including mine:
SDARS Region should be set to unconfigured:
727-04-01 xxx0 xxxx xxxx
SDARS Region: 0=unconfigured, 1=U.S., 2=CANADA, 3=no content.
SDARS Data Services should be set to unconfigured:
727-04-01 xxxx x0xx xxxx
SDARS Data Services: 0=unconfigured, 1=Data Services, 2=no Data Services.
SDARS Region: 0= unconfigured causes ACM module to throw misconfiguration DTC because it seems SDARS Region should have some configuration if the car has a SDARS Antenna. From what I realised best settings in this case are:
SDAR no content
727-04-01 xxx3 xxxx xxxx
SDARS No data services
727-04-01 xxxx x2xx xxxx
Your vehicle is an exception. This error will only be seen in certain radios and of those only equipped with SDARS exported from NA. It is not a MIL activating DTC. The âno contentâ setting tells the receiver to ignore the no service flag, subscribed or not. However, good catch.
Yes, specifically those who are keeping the US ACM that is equipped with SDARS. Many EU imports from the US replace the ACM with an EU equivalent to enable DAB and traffic features.
Just keep in mind that the less free memory you leave the most likely a reformat will be mandatory in the future for updating mapsâŚ
But, you can reformat the unit, so thatâs not bad⌠in fact itâs recommended, since itâs faster and cleanerâŚ
Nevertheless keep that in mind, you are âsaturatingâ the APIM with packages, so MEM ERRORS or failed upgrades in future updates are expected to happen, specially for big packages like mapsâŚ
