LST_PKG_FILE_NOT_FOUND please post screenshots of your usb sync my ride folder and the contents of your autoinstall (notepad)
I may have made a typo in the file names.
As per the guide notice once you out the factory mode on you can't exit, saying you have a error does not help in the slightest post more information if you want help. Check the md5 of the downloaded zip file to make sure download integrity is good
Let me look in to this, I haven't personally tested the us files since the guide rewrite possibly a missing file no worries I'm sure it's fixable, worse case scenario we use the old version of the guide.
You can try it, worse case you need to use the reformat tool to start over.
I can't answer that unfortunately
Looking in to this.
From my research it appears there are 2 common reasons for this error.
Usually caused by a inproper copy to the USB, make sure to SAFELY REMOVE after copying as windows can still be doing stuff in the background, i've had it multiple times where it says it's in use and therefore unable to safely remove, a few minutes after it lets me do this.
The other cause is if you have "Delay" missing from the autoinstall.lst file but this isn't relevant in this case as the option is there.
F8 maps only work on 3.2 and above is my understanding.
this step "Upgrading to Sync 3.4 19274"? that has a download with the autoinstall.lst file included.
Multiple are reporting this issue, i think there must be something wrong with this, can you try the navigation voice (order doesn't matter) and i will look in to the map data in the meantime.
Is any one with this issue able to chat with me on discord or facebook/cyanlabs
