Change firmware ACM on European Ford fusion 2020
Hello, I want to change the firmware in acm ls7t-19c107-cc to European in Ford fusion 2020, I want it to work fully rds.
I read that I need to change vbf On
KS7T-14D101-CA
KS7T-14D099-FB
Can someone share this with me?
If you are looking to get DAB, this radio will not do it.
I would like the names of radio stations to be displayed. And apparently after a software update this will be the case.
Removed.
Thanks a lot for your help but something is wrong. When I try to install the software I get an error. Is it possible that it is because the software I am trying to install starts with KS7T and my AMC is LS7T?
You never got to the programming or writing of the firmware. Check your adapter firmware and use a USB adapter, which you probably have using UCDS. You might need to upgrade the license for UCDS.
Tomorrow I’ll try to do something, if I can’t do ucds I’ll try forscan. A few weeks ago I updated ipc to the latest because I installed a counter from Mondeo mk5 and everything went smoothly and here’s a situation like this…
Success! Updates have been uploaded, now the FM radio station names are displayed and I even saw the radio station logo for a moment. Is there nothing that can be done with the Dab radio? It works but the radio station name is not visible.
FMods has something for the DAB station naming, not sure if it would apply here but you could take a look.
FMods - Forum
Hello again. However, not everything works as well as I thought. Today I noticed that on this software the navigation does not connect to GPS. There is no signal. It is a great pity because it looked promising. After returning it works as before.
