Change IPC language
Hello guys, my car is a 2020 Ford Fusion American and I have a question: When changing the language in SYNC3, it does not change in IPC as in the 2017 and 2018 models? Note that I have done a lot and a lot of changing the settings from the FORScan and the As-built and adding the country codes in APIM IPC FCIM ACM and nothing remained bad and I did not do it, what is the solution?
