Please help with the following i own a 2015 Ford F150 XLT that has an upgraded Sync 3 navigation system. Recently, I acquired a Lariat cluster and I have several questions. Can I simply copy the as-built configuration from my XLT to the Lariat cluster? Additionally, I am having trouble finding how to turn on the turn-by-turn navigation display in the new cluster and how to enable the numbers fuel, temp ,etc on top of the gauges. Can you help me with these issues?
You “Might” be able to transfer the AB directly for the most part. It depends on how different the calibrations are. You might want to look at the IPC AB Databases and determine that once you look at both in Forscan.
That Database should answer all your questions.
