European TCU in US car
Hi All.
Help me figure out where I’m making a mistake, I just can’t set up the TCU.
Few details:
I have a FORD Explorer 2020 from USA to Ukraine with preinstalled TCU LB5T-14G229-AN and of course it didn`t working in UA,
so i bought a european TCU LV4T-14G229-DP both of them have FB40 cert
After installation it stuck at UNPROVISIONED MODE :(
I tried to update my AB to it and change 754-01-01 from B132 to B138 - no result.
Run through FACTORY MODE (xxx9, xx00, B138) procedure - no result and if earlier he at least received the country identity, after that he stopped getting it :(
I ask you to direct me to the right path, because I no longer know what also try to do. :(
Welcome to the forum. You’ve been here before…
Could you please post the APIM and TCU asbuilt from FORScan? It would be helpful to post the backup ABT files. Both the original and replacement files for the TCU.
APIM AsBuild
;Block 1
7D0G1G1AA0A210318C9
7D0G1G2022B0C14CAF1
;Block 2
7D0G2G1504C1004B43E
7D0G2G20B7C98ACB65C
7D0G2G3CE05AF
;Block 3
7D0G3G10006060200E9
;Block 4
7D0G4G1000001900B78
7D0G4G20002DF
;Block 5
7D0G5G11ABD1AA42EA0
7D0G5G28563
;Block 6
7D0G6G110EE
;Block 7
7D0G7G11A003300002C
7D0G7G2000075300085
7D0G7G3005656940021
7D0G7G47658
;Block 8
7D0G8G1E24710C403E0
7D0G8G2400000401071
;Block 9
7D0G9G1631FCEEBFE1A
7D0G9G2C07E5F081FA6
7D0G9G38044000000A7
7D0G9G4000000002004
TCU AsBuild
;Block 1
754G1G1B13800000046
754G1G2005E
;Block 2
754G2G11B2099
;Block 3
754G3G17D7D7D7D7DD0
754G3G27D7D7C7C7CCE
754G3G37C7C7C7C7CCD
754G3G47C7C7C7C7CCE
754G3G57C7D7D7C7CD1
754G3G6001E7D7D7DF9
754G3G77D7D7D7D7DD6
754G3G87D7C7D7C7CD4
754G3G97C7C7C7C7CD3
754G3GA7C7C1E84
;Block 4
754G4G17C7C7C7C7CCC
754G4G27C7C7C7C7CCD
754G4G37C7C7C7C7CCE
754G4G47C7C7C7C7CCF
754G4G57C7C7C7C7CD0
754G4G67C7C7C7C7CD1
754G4G77C7C7C7C7CD2
754G4G87CE3
;Block 5
754G5G17E007E007EDB
754G5G27E7E7E7E7ED8
754G5G37E7E7E7E005B
754G5G47E7E7E7C7ED8
754G5G57E7E7E7E7EDB
754G5G67E7E7EE0
;Block 6
754G6G17D7D7D7C7CD1
754G6G27D7D7D7D7DD4
754G6G37D7D7D7D7DD5
754G6G47D7D7C7C7CD3
754G6G57C7C7C7C7CD2
754G6G67C7C7C7C7CD3
754G6G77C7C7C7D7DD6
754G6G87D7D7D7C035F
754G6G97C00000000E6
754G6GA00000071
;Block 7
754G7G103C0A014F1CB
754G7G2681E0F0A181B
754G7G34B00640A0220
754G7G43C1E1F425879
754G7G50F194CFF12EC
754G7G601127B
;Block 8
754G8G105060605057F
754G8G2020105050577
754G8G3050505050983
754G8G40A0A0A0A0594
754G8G5056D
;Block 9
754G9G170726F64304A
754G9G2346E61776949
754G9G36669666F727D
754G9G46400000000CC
754G9G5000000000069
754G9G600000000006A
754G9G700000000006B
754G9G800000000006C
;Block 10
754GAG1555011
;Block 11
754GBG100000000006D
754GBG200000000006E
754GBG300000000006F
754GBG4000000000070
754GBG5000000000071
754GBG6000000000072
754GBG7000000000073
754GBG8000000000074
;Block 12
754GCG100000000006E
754GCG200000000006F
754GCG3000000000070
754GCG4000000000071
754GCG5000000000072
754GCG6000000000073
754GCG7000000000074
754GCG8000000000075
;Block 13
754GDG17C7C7C7C3C9B
754GDG20ADE1E012CA3
;Block 14
754GEG1140185
;Block 15
754GFG1280A0000A84B
754GFG240A258078033
754GFG340F0C80F057F
754GFG405037C
;Block 16
754H0G13FB1
;Block 17
754H1G10174
;Block 18
754H2G103047B
;Block 19
754H3G10A0A0A0A0AA7
754H3G20A0A0A0A0AA8
754H3G30A0A280000B3
754H3G4000000000078
754H3G5000000000079
;Block 20
754H5G1000000780F04
754H5G20277F7
;Block 21
754H6G103E869
;Block 22
754H7G100000000007F
754H7G20080
It was on TCU before.
Is your Explorer Gas/Electric Hybrid (FHEV)?
Your APIM shows 504C (PL) as the country code and the TCU shows 5050 (UP) as the country code. These need to be the same.
I’ll work thru this and get back to you later…
My EXPLORER is Gas (B132 originally), but TCU is from PHEV car (B838).
TCU Code 5550 UA (if i understand correctly). Originally it was 474D (Germany). I tried different variations on APIM and TCU.
Since you are in Ukraine, this is what I would think you would use.
The TCU is from a Ford Focus or Kuga PHEV?
Does the APIM show the TCU serial number with this unit installed?
I think it from KUGA III PHEV
Yes
OK, it will take me a bit to review…See your PM, I need your VIN by PM.
Does anyone have any thoughts on this?
See your PM…
