I converted my explorer PI from 4-8 inch. Sync 2 system out of a Taurus. How do I get the correct download for the explorer
Find the VIN online for a 2014 that is for sale. Use that VIN at the Ford link below and you will find most the settings you need. I would look for an XLT that has navigation to start. You will of course not have heated seats, Ambient lighting and several other things you will need to turn off. Then you will need to use the SYNC 2 database on here to refine the settings.
Index - FordServiceInfo.Com (motorcraftservice.com)
There is no one that is just going to give you the correct AB settings when they don’t know what options your PIU came with.
