This is not SYNC related but a Ford mod
Those that have a later model Ford F150 or Expedition will have a Cigarette lighter plug to the right of the Sync screen on the passenger side in the US. It appears the later Fusion model has a shape that would work for this also. These are rarely used anymore and when they are it’s usually to use an adapter for a USB plug.
The newest Ford’s come with a cylinder USB module now. These are all self-contained and do not require a separate power module that takes up more space. The 2nd and 3rd row plugs use the older larger ones. Ford has made this simpler and they snap right in. The cylinder module is below.
While looking at the plug I noticed it would fit one of these USB modules.
All I needed was a power plug that was rather hard to find. I found a harness that would have the small 4 pin(only 2 used) plug need to make this work in a 21-22 Bronco sport. The harnesses actually have 2 of the needed plugs. I soldered the wires in place of the old plug and now have 2 working USB ports. I am sure these could work in other Ford models if they had the right size opening.
