Failed BdyCm Update
Tried to update my BdyCm Module and my internet went out somehow and it failed. Now I can’t turn my car on or anything! Help! Any suggestions?
Internet has nothing to do with updating modules. Forscan downloads the files first so if the internet went out it would not matter. You could try doing it again. If that does not work or you can’t than you probably just bricked your BCM and you will need a new one. Also you will need the keyfobs reprogrammed.
Well apparently you’re wrong because the minute my internet rebooted, I tried again and it went through perfectly fine.
Glad to hear it worked on the second try.
What an awesome way to make new friends…
