I have a 2016 Fusion and a 2015 Expedition. Both titanium edition. The Temperature/Fan repeaters don’t popup in the Expedition like they do in the Fusion. I understand they may be different due to vehicle architecture. I have gone through AsBuilt and the Easy method and both seem to indicate the Expedition Temp/Fan should popup. Reading through many posts here and forscan.org, I’ve made many changes but can’t seem to get the popup. I haven’t found any Expedition posts though.
Unfortunately, making that change did not allow the popups to happen. I verified my change after reboot. I also note that in Easy mode I see that the Climate Control Repeater is now set to Single after reboot.
I have not seen anything that would make this work. That change works for C1CMA vehicles with the same issue, but I would say CGEA 1.2 does not support this.
