Yes, I tried master reset which didnt change nothing.
I saw now that when I connect phone, for a moment appear that is charging and after second is not charging anymore.
If you did a master reset and you doubt about the sw you installed, you can always try another build.
BUT, since you are mentioning that the phone is not charging, I think there’s something else going on here… Try another cable and/or port and check if that’s still happening…
