Hello,
I have a 2013 ford fusion that lost sound. I purchased a new ACM and plugged it into ForScan but im not sure what to do now.
I have the as built data that i downloaded from the ford site. Can someone instruct me what i need to do next ?
Hello,
If its the same model ACM (eg S only has AM/FM, SE has AM/FM/XM, Ti AM/FM/HD/XM) you just need to go into ForScan, module config ASBuilt, select load from file and point it to the file you download from Ford and then hit write all.
