Ford SYNC 3 - Automated Method - Update to 3.4
CyanLabs does not support changing region, repeat the process with your original region. (NA)
Thanks. I do that. Anyone knows how change region?
You need to change some as-built and install cut down EU maps.
What parts I can cut down?
Share your reformat.lst contents (open in notepad)
MAP=1U5T-14G421-BAF_1580858019000.TAR.GZ
MAP=1U5T-14G421-BBF_1580858113000.TAR.GZ
MAP=1U5T-14G421-BCF_1580858198000.TAR.GZ
MAP=1U5T-14G421-BDF_1580858255000.TAR.GZ
MAP=1U5T-14G421-BEF_1580858316000.TAR.GZ
MAP=1U5T-14G421-BFF_1580858475000.TAR.GZ
MAP=1U5T-14G421-BGF_1580858524000.TAR.GZ
MAP=1U5T-14G421-BHF_1580858580000.TAR.GZ
MAP=1U5T-14G421-BJF_1580858694000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BH_1582138650000.TAR.GZ
ENH_DAB=1U5T-14G658-AE_1553188025000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBE_1580861854000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCE_1580861916000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDE_1580862152000.TAR.GZ
GRACENOTES=4U5T-14G423-AA_123694.tar.gz
APPS=5U5T-14G381-EB_1581452369000.TAR.GZ
VOICE=5U5T-14G391-AK_1571068712000.TAR.GZ
1U5T-14G421-BBF 452Mb Sync3 v3.2.19324 EU.1.19 (EU_Map_ext)
1U5T-14G421-BCF 1.6Gb Sync3 v3.2.19324 EU.1.19 (EU_North_UK)
1U5T-14G421-BDF 1Gb Sync3 v3.2.19324 EU.1.19 (EU_Iberia)
1U5T-14G421-BEF 1.6Gb Sync3 v3.2.19324 EU.1.19 (EU_France)
1U5T-14G421-BFF 2.3Gb Sync3 v3.2.19324 EU.1.19 (EU_Central)
1U5T-14G421-BGF 1.8Gb Sync3 v3.2.19324 EU.1.19 (EU_South)
1U5T-14G421-BHF 2.4Gb Sync3 v3.2.19324 EU.1.19 (EU_East)
1U5T-14G421-BJF 22Mb Sync3 v3.2.19324 EU.1.19 (EU_Cyprus)
^^^ Remove countries not needed ^^^
Can i ask how come you have a blank line and are missing? 4U5T-14G422-BAE
Remove voices not needed vvv
4U5T-14G422-BAE 2.2Gb Sync3 v3.2.19324 EU, Nav Data version: 800. Packaged on: 20190915 (3)
4U5T-14G422-BBE 2Gb Sync3 v3.2.19164 EU, Nav Data version: 800. Packaged on: 20190915 (5)
4U5T-14G422-BCE 1.5Gb Sync3 v3.2.19324 EU, Nav Data version: 800. Packaged on: 20190915 (8)
4U5T-14G422-BDE 1.9Gb Sync3 v3.2.19324 EU, Nav Data version: 800. Packaged on: 20190915 (4)
(1) NA (ENU,FRC,SPM)
(2) EU (CZC,DAD,DUN,ENG,FRF,GED,ITI,NON,PLP,PTP,RUR,SPE,SWS,TRT)
(3) EU (DUN,ENG,FRF,GED)
(4) EU (DAD,FIF,NON,SWS)
(5) EU (ITI,PTP,SPE,TRT)
(6) CN (ENU,MNC)
(7) ANZ (ENA,ENG), SA (ENU,PTB,SPM), TUR (ENG,GED,RUR,TRT)
(8) EU (CZC,PLP,RUR)
I cut down ready my problem 78000 ended file. But not yet tried download to car.
Enough if I take out this files reformat.lst files?
Yes no need to delete the file removing from reformat is enough. Note you will need to make changes to your asbuilt for this to work still
How I make changes asbuilt?
Again, Cyanlabs does not support changing region, i have given you tips, it’s on you now.
If I update them with version 3.2.20021, what type of region should I use to control the Spanish language in voice commands?. which of these regions (EU, ANZ, ROW, CN, NA)?
the previous version was 3.0.19205 and there was also the voice command in English.
Could not be placed in Spanish
There are way too many voices for me to know, did you take note of your IVSU’s?
This is the IVSU, but this version also shows the voice in English, it could not be switched to Spanish.
adittional the new version does not have Android Auto.
I assure you it does, if your old version was also not Spanish then i can not help.
¿Cuál de estas regiones (UE, ANZ, ROW, CN, NA) has spanish?
The new version of the application has a list of languages in each region, the webpage also does. Click the ? On the app next to region drop-down.
Is it possible to downgrade sync version 3.4 19101 to 3.3?
How would I do this procedure?
