Ford SYNC 3 - Automated Method - Update to 3.4
Yes, that is correct :slight_smile:
hi, is there any update to show navigation on the small screen in the Dash Cluster / Speedo - with CarPlay? I saw it working with Android but no CarPlayā€¦
Hi @revelares if it doesnt work after this update, then it is a requirement of Apple/Carplay to enable this not Ford/Sync.
That is what i am trying to check - if anyone was able to do it using carplay or if it is on Apple to enable that functionā€¦
As stated this is likely an Apple update requirement.
Easy way to confirm this is if your built in nav (or an android auto enabled device) is displaying in the IPC correctly but your iOS device isnt, then you know its a waiting game for if/when Apple enable it.
Hi,
Iā€™m having trouble getting all the languages to work with this update.
Iā€™ve updated to 3.4 19101 using the Ford Sync Downloader. I did a master reset two times after the installation was finished. Unfortunately, I seems I canā€™t select Swedish as my language. There are only 4 languages in the list; English (UK), Spanish, French and Portuguese. Iā€™ve tried to reinstall pretty much everything, but still canā€™t get Swedish to show up. Do I have to change anything in the as built to make it show up, or is there some other way to get around this? Any help would be appreciated!
Hello!
Everything went perfect!
Downgrade and after that upgradeā€¦ now Iā€™m on 3.4 (19101). It took ~50minutes.
Thanks for your support and help! Youā€™re great!
If found a bug: if I restart the Sync3 the radio shows the last station looks like it is on.
But it is off. If I switch ON it is working, then OFF it shows Radio OFF.
After restart the Sync3 it shows again the last radio station but switched OFF.
hi,
I have the sync3 version 3.4 19101. I had before the 20021 But I had had problems. And with the 19101 too. So Iā€™d like to go back to the official version, the 3.2. Can you give me the precise steps to do it please
Provide your ivsus from before you upgraded. If you didnā€™t take note of these then you will need to test various packages to go back to 3.2
Hola, realicĆ© actualizaciĆ³n de 3 a 3.4 con la descarga por la alpicacion, descarguĆ© la regiĆ³n NA y estoy en sudamerica, se puede corregir la regiĆ³n? me muestra error en los mapas, creo que era la regiĆ³n ANZ, que me recomiendan hacer? Gracias
downgrade and reflash the correct region, i donā€™t support changing regions.
Alguien me puede ayudar indicƔndome como puedo instalar los mapas de Sur AmƩrica,
Como los identifican: NA, ABZ, ROW?
En que link los puedo descargar para instalar en la versiĆ³n 3.4 20021
Cual es el paso a paso para instalar el mapa?
Muestra un mensaje de error en la pantalla que dice que faltan los mapas
Agradezco la colaboraciĆ³n
Install version 3.4 19101 but i have following problems:
  1. says the USB module is not compatible.
  2. The voice commands come out in English, how can I change them to Spanish?
    I am from colombia
Thank you
What`s wrong?
English please. Thanks.
Looks like you are trying to install nav to a non nav unit or EU maps on a NA unit.
I have nav. Yes I try instal EU maps to CA F150 model.
Can I do that?
EU navigation is 64gb, you can not fit EU maps on a NA / Canada model as they are 32GB
Hi,
  1. This is likely due to having the older USB hub you will need to upgrade to the new hub.
  2. Not sure on the language, did you take note of your previous IVSUā€™s?
Can I solve this problem?
