Ford Sync 4 Swap Cameras Dim Now?
Hello,
So i have gotten the sync 4 swap on my 2019 ford f350 platinum just about good.
However. Cameras have become darker or harder to see in darker areas such as parking garage. Is there something i can do in the asbuilts to change this?
I have also saw someone mention
“to fix the quality issue, you can run a wire between the IPMA and the APIM. Just make sure youre using a 12” apim, since the 8" one doesnt have the right connector for the digital feed."
They show 2 part numbers
ML3Z-10E929-FAA
ML3Z-10E929-FBA
They combine the two and remove pin and use that…
Has anyone heard of this or does this make sense?
as for the programing they mention to change
IPMA 706-01-01 xxxx xxxx x0xx
and
APIM 7D0-01-02 x0xx xxxx xxxx
Thanks in advance for any input
This switches between an analog or digital camera type. What camera type is installed in the vehicle now?
This affects the rear braking assist. Might be using a screen overlay which could affect the picture.
Keep in mind you truck was never intended to support Sync 4 .
